2.29+, Wyze Sense Hub, and Wyze Cam Outdoor Updates - 4/8/22
Hi - I’m am have the same issue as discribed by Seapup.
2.29.2 app for iOS 15.4.1 hangs when attempting to access Wyze app click on Account > Firmware Update from the Home tab at bottom of app. Screen displays ‘Loading’ for a second and then screen is frozen … can’t even back out. Have to force close app. The screen shot Seapup has is the same screen I see.
Click on Home
Oh, I see, thanks, I missed his post for some reason, that makes sense :+1:
It seems this app version is having some issues related to the firmware functions. Hopefully they can issue a hot fix soon.
My troubleshooting steps are in my comment above (2nd or so from the top). I even just took the extra ordinary step of removing and reinstalling the app with no change in the issue. And I’m uploading a video to show what I see, To echo what others have said, once the app freezes, there’s no way out other then to force close the app.
As for what Wyze equipment I have, I have a mix of V2 and V3 cams, an Outdoor Hub & Cam, Gen2 Pan Cam, Sense System (with leak and climate sensors), V1 white lights, V1 and V2 plugs, and a switch. I think that’s everything, lol.
Here’s the video of the app freezing:
Sorry I didn’t answer your question. The WCO Base Firmware was paused twice and it is not available for download. The First issue bricked some bases, note states that if you load 4.16.2.66 you can not revert to a previous version of firmware. So in their great wisdom they removed all the firmware versions from the release notes for download including the one that I have 4.16.2.45. What a circus :astonished:
I also removed the app (not the data), turned off the iPhone, turned on the iPhone, reinstalled the Wyze app. Still have same issue.
I know they were beta testing a 2.30.x app version, and this says it is just a “Hot Fix” for some specific things, so hopefully they’ll have another update really soon and include the fix for these issues.
I can confirm that the 2.29 version, just installed, the update Firmware Menu is empty. I go to the About menu, select Beta Option and the page just sits their saying Loading and nothing appears.
Interesting you guys have one that freezes during loading. Mine, on Android, is just empty. Seems like an obvious issue in both versions (Android and iOS) though.
Mine on Android Is empty when you go to the Firmware Update Page. But when you go to About>Beta program, it freezes and just says loading.
Forum Mavens and Moderators are just fellow users who volunteer time to help other users and maintain forum order. We don’t have access to Wyze’s internal info such as scheduling. We can help push Customer Service tickets up the chain and bring issues such this to their attention. I will run this up the chain, but it’s the weekend, routine firmware updating is not an emergency, so we may not get a response until Monday.
For those running iOS who really want to update firmware from the Wyze app Home > Account > Firmware Update page, I figured out a slightly difficult and frustrating way to get the page to load. You may need to try this a few times to get timing correct.
Take note of where the Account icon is on the Wyze app Home page. Take note of where the Firmware Update line is on the Account page.
Force close the Wyze app.
Start the Wyze app. Do not wait for the page to load. Start spamming the location of the Account icon.
As soon as the Account page loads, start spamming the Firmware update line.
If you manage to tap the Firmware update line before the Wyze app finishes the initial load process, you will be successful. Yes, this is a painful workaround.
How on earth did you even think up that solution? That’s amazing.
Also, for now people should be able to update through their device settings - device info section if something is important or time sensitive.
I’d prefer not come across as telling Wyze what the technical problem is. Bad juju.
Seapup - Your solution actually works. It is hit or miss.
Thanks for the info. Appreciate it. :slightly_smiling_face:
I just updated my android wyze app, and the firmware update for sense hub, hangs the same way. What is going on at Wyze, first my doorbell, now this…
Becase Wyze wants non paying user gone?
Dear all,
Thanks for your feedback. We are working on this issue and try to fix it ASAP.
Thanks,
Xiaolong
Hi spamoni4, can you help submit a log and take a screenshot for us to investigate the issue? For somehow, I can’t reproduce the issue on my iOS device.
Thanks,
Xiaolong
Sure Can, below you will find the information requested
ANDROID (Pixel 6)
Note: The screens that show loading actually locks up the app. I need to shut the app down then restart the app.
App Version: 2.29.2.127
Log #: 537959
Firmware update menu
Beta Program Screen in About
iOS Device (iPhone Xs)
App Version: 2.29.2.a3
Log #: 537969
Beta Program Screen in About (This looks ok)
