Zone keeps running after system shut off
I have the wyze sprinkler online for three months. It setup quick and easy and has been a pleasure to use.
Yesterday, for the 3rd time, I received a call from my wife late morning telling me that the sprinklers were on.
My system is scheduled to run until 630 am on smart schedule.
Apparently, sometime a random zone stays on even after the system shuts it off.
Support has been no help.
Anyone with ideas or having/had the same problem a found a solution.
@john20
I am sorry this is happening. When you worked with support did they give you a ticket number? If this happens again can you also do a log right after and post the log number here.
have sent several logs from the last occurrences.
They mail me a new unit I guess assuming something is bad with the current
The thing that gets me is that the zone that remains on is not the same as the previous occurrence.
[Mod Edit]: Signature block has been manually removed from this post. Such information often gets included inadvertently when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
Wyze can only see the logs when you give them the number, check your email history or the log history in the wyze app and send the number here please.
Could you also get your ticket number please. It should be in the email from support.
Sorry. I cannot locate those emails
Moderator Note: Personal information has been manually removed from this post. Such information often gets included inadvertently in an email signature block when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
Probably not convenient, but if you can catch a sprinkler zone running when it’s not programmed to be on, use a multi-meter and check to see that the timer is putting out 24ish volts AC on that zone that’s running. It’s possible that your problem could be in your valves, not turning off when they’re supposed to, but you say it’s not the same zone that’s running when it’s not supposed to?
I tried this it just shorts the zone and shuts it off so no you can’t check if the voltage is 24v while running
I have this same problem on latest firmware with all zones and multiple controllers not a valve issue as I put my old controller back and it works correctly
Seems it’s the bug introduced in firmware 1.0.7 that is still not resolved in 1.0.10. Is there anyway to roll back firmware to 1.0.4
Did you ever get a reselution to this issue?
I have the same issue on fw 1.0.11
Any help with this issue? I just got the wyze sprinklers and am running into the exact same issue. The only way to turn off the sprinklers is to cut power to the controller.
I am also on fw1.0.11
I had to clean out the sprinkler line at its control valve Then it was fine b
Same problem for me, with firmware 1.0.11 :rage:
I solve my problem… I bought an Orbit b-hyve wifi and everything back to normal. No more problems. :roll_eyes:
Too bad that I thought it was a valves problem… I changed 6 valves before see this post and realized it was the controller. :rage:
I also have had ongoing glitches with this controller. I now have an orbit b-hyve on order to replace the glitchy wyze controller.
I have just experienced the same issue with a quick start zone run. The horror is that I was traveling. A 24 minute run cycle failed to turn off and 18 HOURS LATER I discovered by chance while scanning my cameras. What a disaster! Out of desperation, I ran a one minute cycle on the zone and the controller succeeded in shutting it off. Support remedies for troubleshooting are unacceptable for anyone away from the home. I may use a Wyze plug to power cycle the controller on an automatic schedule several times a day to prevent this epic product fail from reoccurring.
So… Nobody at Wyze has anything to say about this ongoing issue? Apparently my sprinkler has been running for hours. My yard is a flooded and the zone is not anywhere on the schedule today. May have been running for 2 days…?
Found this thread, have this same issue, can’t fix it. Sprinklers were stuck in the ON position for HOURS. I deleted the sprinkler and readded. Now they don’t come on by schedule anymore at all. I have to manually turn on every morning. Completely useless as an automated product unless this is fixed.
Does Wyze have a solution for this? (both the zones staying on for hours as well as a schedule not triggering at all). I submitted a ticket with a log and nothing.
