Sprinklera
date on the back of the sprinkler is 10/2020; worked well until now - seems to be stuck “ON” the zones show on the controller, the zone shows blue when selected but the water flows through all zones unless it is manually shut off. wiring seems fine, I can select any zone using the phone app and i can access the zones to shut off but get no response. 4 orbit anti-siphon controllers, flushed system and re-flushed. all 4 work manually - any thoughts
deleted sprinkler from WYZE app, reloaded went through setup- same issue. constant water will not shut off
resolved
How was your issue resolved? Saying that here will help the community in the future that find this topic. Thanks in advance for the update!
Found this thread, have this same issue, can’t fix it. Sprinklers were stuck in the ON position for HOURS. I deleted the sprinkler and readded. Now they don’t come on by schedule anymore at all. I have to manually turn on every morning. Completely useless as an automated product unless this is fixed.
Would you be so kind to share your solution?
The no schedule is in a couple of other posts - please open a ticket with Wyze so you can get added - the more tickets open, the higher the chance of it being looked at. This is a software issue, probably from the latest app update, but there is no fix.
This topic was automatically closed after 30 days. New replies are no longer allowed.
