I have a WyzeCam V3 with spotlight, and the spotlight won’t turn off. It is on 24 hr per day. I have unplugged the camera. Reset the camera, changed firmware. I don’t know what else to do. Any ideas?
Same here. Happened after the latest firmware update. Submitted a log, but haven’t heard back yet.
OK, sorry you have this problem also, but at least we have an idea what happened.
Did you ever get this resolved? Mine is still shining 24/7…
No still no luck.
Mine was actually off when I woke up this morning. However, I still can’t access it in under “accessories”. Nothing continues to happen when I try and select it.
Mine is only off if I remove the power, it is annoying. I have no idea what is wrong.
OK fixed it by replacing the spotlight I was worried when it updated the firmware of the device, but it now shows on the play screen, and can be turned on and off.
