The power socket on the v3 Pro is smaller than on previous cameras. I have a long USB cable running through my attic to power this camera and found that the micro USB connector on the cable will not insert all of the way in to make contact. Worked fine on my WyzeCam and v3 cameras.
Thanks for that heads up. I will check some of my non-Wyze cables…
That is definitely a major flaw. The U in USB stands for Universal and I guess Wyze decided to make it’s own cable ![]()
The V2’s were pretty small too. I had to whittle the plastic around my plug end down.
The step down you see is actually for waterproofing. There’s some silicone in there to act as a seal. The only way for it to be waterproof is if the cable is snug, so only some sizes will fit
I think that it is common to need a longer cable than Wyze supplies, so if Wyze wasn’t going to sell one, the support group should have tested and recommended a 3rd party cable that works. I took a Dremel tool with a sanding drum, set it to low speed and very lightly sanded down the end the micro USB connector plastic housing. When I plugged it back in to the camera, the power light came on.
I have mine attached to a 20ft ext. from Amazon that fits nicely, albeit very snug.
I have had this problem with my V3Pros that I have been setting up. There are many instances where I need at least a 10-15ft cord to get it in the right position, and so I have to use a 3rd party cord, but the tip wouldn’t fit in the V3Pro port.
I did similar to alepold: I took a file and slowly filed the plastic on the third party cord until it finally fit in there with enough pushing. ![]()
Please remember that this is a thight fit for waterproofing, if you sanded it down too much you won’t have a seal and water will get in. Camera is waterproof if you use provided cables or tight cables, the usb connection itself can not be waterproof
This is why they should’ve left it the way the V3 was, with a little cable coming out of it with a rubber cover over the connection. At least that way we could use longer 3rd party cords. For a lot of people, they basically have to sand down the tip of the 3rd party cords or they can’t hang their camera where they want.
Wyze should either come out with a coupler-adapter that lets us connect any cord to it, or at least offer their own affordable long cables that will fit right.
Another option is that people could buy their own little coupler, then plug the cord that came with these, into the cam, then plug that into the coupler and another longer cord into the coupler, then waterproof where the 2 cords connect (ie: wrap silicone tape over that connection). That is an option I have done before.
Yeah, I rubbed the last maybe 2 eighths of an inch of the plastic housing across a sanding block on all sides for not very long and that was enough to get my third party micro USB male-to-male cable to engage properly in the V3 Pro’s recessed port
Even the original Wyze Cam (as shown in the photo) is hard to find replacement cable that will fit.
There aren’t that many companies still making USB-micro cables. So far as I can tell they all come from the same country as the Wyze Cams and all other cheap electronic stuff, but 99% of the USB-micro cables won’t even come close to fitting into that recessed jack.
I needed to replace the cable on an old v1 Cam and none of the USB-micro cables I had lying around would fit, nor would most of the ones at local stores. I found one at Walmart from onn brand that fits the v1 Cam.
