multiple cams have had this issue (3 of 8) at varying times - never together
net speed 400 MBPs
tried a card change (and mfg change)
cam ver 4.36.2.5
Wyze app ver 2.23.21
Anyone having to RESTART their WCV3 cams to get the “VIEW PLAYBACK” to record? I have had to RESTART several cams several times to get the VIEW PLAYBACK option to show/get anything to record.
The “View Playback” is specifically for the SD card. You might want to try a different card since some them corrupt easily. You could also try to reformat it in the camera. Not sure why restarting the camera would make any difference. You might also have a slow network connection causing issues.
