WyzeCam v3 here…working great…except with the wifi on certain channels.
A WiFi network set to channel 12 or13, the v3 works great, EXCEPT when the SSID is set to “hidden”… the camera refuses to connect. Tested with several different routers, different model routers and routers from different manufacturers ( to make sure it’s not something unique to my setup) .
Tried 4 different v3’s, all the same issue, problem happens on old and the latest version of the firmware.
The V2 has no problems with channels 12/13, ssid hidden or not, the V2 cam’s connect just fine.
If you want to test this out, set your router to channel 12 or 13, and then set the ssid to hidden. The camera will refuse to connect. It appears that this is a firmware issue.
I don’t have a V3 yet but I wonder if this is even technically a bug. I’d think a lot of consumer grade gear would have issues with unbroadcast SSIDs. Worst case you could add a segment with an advertised SSID just for your V3s…
12 and 13 are legal in the USA - but only in low power mode. Many consumer WiFi devices do not even offer them as available channels. BTW, channel 14 is totally illegal in the USA.
