Hi there, I just discovered a bug on the Wyze cam V3 units.
Because I’m a new user, I cannot send you the video footage.
To clarify:
I’m using the firmware: 4.36.10.4054
I tested on 2 v3 cameras, both have the same bug.
The bug.
When looking carefully at the timecode. lets say… 7:59am when it reaches 8:00am, it actually SKIPS a minute and goes directly to 8:01 am. The bug seems to do this during EVERY hour of the day. It will skip the XX:00 hour and go to XX:01.
BTW, I tested it on the v2 and the pan scan and they are fine. This issue is only on the V3.
Good morning, @stevensgl. I just tried this on two Cam Floodlights and one Cam Pan V3, all of which have the latest firmware, and I don’t see it happening. I only tested it once, from 10:59 to 11:00, and it rolled over correctly. I’ll try it on some other times later in the day.
Hi there!
thanks for the feedback.
This is very strange. I uploaded 2 clips to my Google drive.
Feel free to take a look.
Please remember this issue is with the V3 only.
thanks
This is a known issue and I believe it was fixed in a recent update. It may still be in beta however. Make sure you keep your app and firmware up to date and it should be fixed soon.
