Loving this, thank you! Long time WyzeCam owner, Been dying for web/pc view, didn’t realize it was in Beta.
Well worth the Monthly subscription to Cam Plus!
Did you ever get them working? I have same problem, can’t find any solutions so far.
If you’re asking grahasi if he ever got his battery powered outdoor cameras working, the answer is no.
I still have not been able to view the live stream on my mac.
Hi Misty, try using the Google Chrome browser and make sure any ad blocker extensions are turned off if you use them.
I have had success on my Mac by using only the Chrome browser, since Safari or Firefox does not seem to work with the live stream feature. also make sure to have a compatible
Wyze cam such as the V2 or V3 cameras and you must subscribe to Cam Plus for each camera to work with live stream.
Hope this helps.
Wyze should ask Amazon how they solved their Firefox problem with the Cloud Cam.
It may have been Firefox’s fault, but eventually the two of them worked out their incompatibility, so there must be a Wyze way to do it.
I hace 6 v3 cameras all with CamPlus, some of which I share. Web view is working for all of my cameras. I also have 2 v2 and 2 v3 cameras that are shared to me by family members. The v2’s do not have CamPlus but the v3’s do. However, in webview all 4 say “Live stream is not supported on this camera.” Clicking on that link it then says " Hang on! This requires Cam Plus for now."
Question is - once live will webview allow you to view shared cameras that have CamPlus?
Add silk browser support please. I’ve been using tinycam pro on my firestick to view my (4) v3s but there are stability issues. I run it 24/7 to view my cameras. Be nice if I didn’t have to buy a mini pc. Thanks for your time and consideration.
Tried this for the first time today on my Mac using Firefox, Safari, and Chrome. The first two would not work, just spinning, spinning, spinning. I get a picture with Chrome but no sound. Is there supposed to be sound?
Reported multiple times, among many other issues. Given the amount of resources available, we need to be patient. Requirements will need to be prioritized once it gets to a real Beta (frankly there’s not enough to test to call it a Beta).
So some of our stuff is going to be low on the list. I thought the login page / timeout would be at the top, but I was wrong I guess
It’s working on my Mac using Chrome (no fancy configurations or changes, right out of the box). It’s slow, but that should improve over time.
I suspect you will have to wait for this, given the laundry list and lack of resources to work on it.
Browsers – Works on Edge and Chrome but not Firefox.
Live Stream – Cam Plus Cameras work but Cam Plus Door Bell does not work.
Live Stream - No Date/Timestamp in Full Screen view.
Events – Cam Plus Cameras work but Cam Plus Door Bell displays sideways.
The wyze cam beta in full screen sets the video to cover, which shows the video… but with the top and bottom cut off dependent on the users viewport/screen resolution. I wrote a tampermonkey script that will fix this for now… but i would suggest that in full screen mode the user has options for how the fit is presented.
For anyone who wants to view the entire video in full screen mode, this simple script just adds a simple css block that adjusts how the video is rendered in fullscreen mode.
The date and timestamp are present in full screen, but often cut off due to how the fullscreen mode works. I wrote a simple script you can use with tampermonkey to resolve this if you are interested.
There is a constant issue with being able to view the ‘live stream’ feed. As in, it NEVER or RARELY will load no matter the browser used.
Also…why is it that the ‘events’ do not match that of the mobile apps events???
I went into my Netgear router settings/devices/QOS and placed the old Chromebook on Highest Priority.
Opened the Beta link and it works for roughly 5 hours continusly until it freezes and I close out, open with 2fa and reload. Cannot have both V2s on at the same time.
Any idea if/when audio will be available on the Web View beta?
Mod Note: This separate topic has been merged to this thread. See above for the answer.
I agree,
I’ve been making small edits to the webview for myself, and I wrote a simple tampermonkey script to remove the shade. Feel free to use it
Even after you posted your other fix for the full-screen scaling it hadn’t dawned on me that the dimming could be fixed in the same way. Thanks for sharing. Hopefully, Wyze will adjust this themselves soon.
