Benn running 4 cams v3 in Wyze Web Live for over 2 years. Removed one. Replaced it with a v4. The smartphone app sees the new camera. The PC browser will not. Using Opera, W11pro. I do not see any controls in web for adding a cam.
Anyone know what’s going on? Thanks!
Maybe try a ctrl-refresh (or whatever the opera equivalent of a “hard” refresh is), or might have to clear cookies/site data. You could try launching edge or chrome and see if it shows there to confirm if it is browser related or not.
If you have any sort of add-ins that block cookies, ads, etc you may try with that disabled just in case something related to the v4 stream is triggering that.
Actually, before all that, make sure it is associated with your cam plus/cam unlimited subscription.
SOLVED! DAVE27 you hit it; I needed to revisit the cameras included in the plus; once I corrected that, it showed up immediately, and I cannot believe the difference!
v4 is simply awesome, I love it, and will upgrade my other cams to v4 as well. Teriffic product!
Thanks for the replies, guys!
