Wyze weather app shows Seattle tho in Colorado
I did a REBOOT and now the Proper city is showing in weather. Not longer showing Seattle as default.
In my case, my Wyze Band display shows the correct temp for my city, BUT NOT THE CORRECT CITY!
The band shows Seattle, but I’m in Southern California. . It was displaying correctly for a few days but no longer. What is stranger still is that the Wyze app on my phone shows the correct city.
Anyone else have this issue?
I moved your post. Did you try to reboot the band? That seemed to work for some people.
Shortly after I posted, I tried re-booting the band and it did indeed work. I was just too embarrassed to go back and re-post and admit that I hadn’t thought of it earlier…
I’ve rebooted my band multiple times and although the correct city is shown, the weather / temp is way off. For example, right now, it’s showing hi temps of 71 / 85 / 91 this week, but all other weather apps (google, wunderground) are showing the announced predictions of 90+.
The current temp is consistent across these sources (79 right now).
This is likely more due to an unreliable weather source than a software bug. At least that seems to be the consensus in this thread: https://forums.wyze.com/t/wyze-band-weather/98101/4.
My band is currently reading 80 degrees while Accuweather and weather.com both report 94. It’s also off of both of those sources by 5 degrees for tomorrow’s high temp forecast.
It’s so unreliable that I’ve been ignoring it, and I’ll probably remove it altogether and just use Alexa for weather.
