Just factory reset, then set up Wyze Watch 47 as Wyze Watch 47 C. All “exclusive” faces will be available.
[Mod Note]: Your topic was moved to Lifestyle category from the Beta category for consistency in grouping similar topics.
Oh great! I hit factory reset and have a QR code, but don’t know what on the app to take me to a reset. The closest I came was to see a screen that says, “Find Watch”, but hitting “Start” only gives me “Connection failed”. Help!
Remove your watch from the device list in the app. Then add you watch again as a new watch , but just select Wyze Watch 47C when selecting in the add menu.
Duh! Thanks! It seems so easy once you know the answer. Much appreciated!
Can someone tell me the differences between the Wyze watch 47 and 47c?
I have a 47 but am wondering if it’s worth getting the 47c to replace it with.
Thanks.
As far as I know its just different outer color cosmetic. Same hardware.
We bought 4 of the 47C and sent them back,bad firmware, the 47c quit updating, lost clock’s face,the steps,sleep mode all failed so we sent them back and I went back k to my 47,only difference is the clock’s faces
Colors and a few watch faces. Still all horrendous.
