Wyze Video Doorbell (v1) Fails To Connect When Doorbell Rings
The device works, connects, shows video fine UNTIL the moment that someone press the doorbell button!
When the doorbell button is pressed, this is what happen:
  • The doorbell speaker tries to sound the ring but its cut halfway with some static noise.
  • If you select the doorbell in the App, it shows the “Connecting sequence Step 1 of 3: authenticating” and it just freezes there.
I am not sure if this is a problem with the legacy chime 12v transformer used to power the Doorbell that does not provide enough power (amperage) when its needed or the the doorbell underwhelming circuitry .
HELP !!
