Happy Monday! ![]()
Wyze Video Doorbell Pro firmware 1.0.68 is releasing today with improved connection stability and a bug fix for an AC power supply status bug.![]()
Read our Release Notes:
Happy Monday! ![]()
Did this break the Alexa integration for Person Detection?
Not that I am aware of, it definitely shouldnât have.
Jason, I confirm that the Video Doorbell Pro is not working as an Alexa trigger for routines. It seems like it is intended to work, since Alexa says this when trying to do a routine trigger for it:
So it tells us we donât have person detection enabled, even when we have Cam Plus on it with Person Detection enabled. So I am leaning toward this being a bug or Alexa wouldnât even mention it as an option.
Iâll bookmark this to post it in Fix-it-first-Friday on the 5th if it still exists by then, but if youâd like, I could try to get you some kind of log, I just donât know what log would help since itâs an Alexa integration issue.
I can provide a log too if one would be helpful.
@carverofchoice @laymanan
Did this just happen after todayâs update to 1.0.68 or is this happening with other FW also?
I have never seen it working. It didnât work for me when I first tried months ago, and I havenât checked again before today, but laymanan told me it was working for him 3 days ago. Discussed in this thread:
So if it was working for him 3 days ago, it sounds like it might be something within the last 3 days.
But I am already on firmware 1.0.68 from beta testing it.
Looks like the capability is still showing as a valid option for other cameras I just checked.
I only noticed it after the firmware update, but I can only verify that it worked 3 days ago. Shows as an option from my other cameras as well and is able to be enabled.
I have reported it, I will update them that I currently cannot confirm if it is tied to this release or not until I have a few more reports.
It looks like the Alexa issue is a separate issue that we have been trying to solve for awhile now. It will work off and on at times and for some users. This is being looked into currently and I do apologize to those it is not working for.
Can I have you both submit logs and let me know the log numbers.
Absolutely. any particular log category/subcategory preferred?
Not that I am aware of.
659331
Done!
What is the Alexa integration for person detection?
It allows Alexa to announce if a person was detected using WYZE AI.
