I beta test the apps and FW and occasionally run into issues. However, there currently is no Beta App for Android. I have 2.26.22. However, Sign-up for the Beta by going here: Become a Beta Tester – Wyze. Once you sign-up, you can start the App, go to Account, About, then Beta Program. From there you click the edit at the Top Right and check the boxes of the devices you want to test the FW on. Make sure you save and back out.
Once you selected the Items you wish to beta test, go back to account then Firmware Updates and you should see it there. Otherwise, go to the actual device and you should be prompted with a FW update.
Note, since there is no Beta for Android, you may have to Uninstall and then Reinstall after you signed up for the Beta App.
As a side note, you can Join and Leave the Beta Program as you wish. But the FW updates will not automatically roll back. you will need to do a manual roll back or wait until the next Production FW update is available.
Hi, I’m new to beta testing. I want to beta test my doorbells. I signed up and updated 1 doorbell. I have 2 doorbells but only one offered the update. I wanted both. Is there a limit? Thanks.
Welcome to the community @Skimour . I am also a beta tester.
There is no limit. This happens from time to time. Have you tried going into the VDB, settings and see if it prompts for an update? Or are you trying from the Firmware Update area under Account menu choice?
Not much more from what I have read, but… You could always try goosing the device list.
Go into the devices you are beta testing, uncheck all, close the app completely via force stop, relaunch the app, recheck th devices you want to beta test, close the app, relaunch and see if you get a beta update on your device. Try both ways, from the FW menu or by directly calling up the device.
I unchecked all, left beta, deleted the app. Installed app, joined beta, checked multiple devices and my V2 and V3 showed up beta available, still No VDB beta available on 1 of 2.
So weird. Not critical. I have given up to be honest and have opted out completely from beta.
My doorbell pro is not connecting via my cellular network? I can view all my other cameras and also the doorbell pro recordings, but it won’t connect ‘live’?
