Firmware Version:
- 4.25.0.305
What’s New:
Improved doorbell speaker performance
Optimized the infrared LED mechanism to reduce lens temperature
Fixed a live stream issue from previous beta firmware version 4.25.0.302
Security improvements
Firmware Version:
What’s New:
Can you provide what Security improvements were made?
Installing update now on my newer doorbell as I was affected with the .302 and live stream issue.
Installation succeeded and I can still Live Stream. Great job on the fix. ![]()
Can confirm that my VDB that had issues with the 302 version of the firmware is now back in business and working as expected with the 305 firmware.
Where are you getting the update from? I dont see it using my app. It shows mine is still on .245
Are you on beta for your doorbell?
I have the test flight app and wyze beta installed but just dont see the beta for the doorbell.
Start the App, go to Account menu option and then About
In About you will see an option for Beta Program, select that. This is where the Beta FW is for devices you wish to test it on. I select all as I like testing and seeing what it coming.
Select Edit (Top Left), Check the boxes next to the device you wish to test, then click save at the bottom.
THen back out to the account menu and click on FW updates and see if anything is available. if not, go to the Doorbell, settings, Device info and click the FW there. You may be prompted about an update when you start the doorbell.
I think you have to opt in for it. On the android, I have to go to the about section in settings and there’s a beta part in there that allows you to select which devices you want to test beta firmware on
ok that did it. Apparently I havent actually chosen products. I swear I did but it must have been when I only had the v2 cameras. Thank you both for pointing out my issues. Im updating now.
Glad it worked. Look at it this way, .302 caused the VDB to stop streaming or at least you could not connect to it and stream. Everything else seemed to work. So you may have saved yourself some anguish which @falkyre and I went through. you missed the excitment of a FW issue ![]()
Did anyone notice the speaker improvements? I’m still on .267 and things are working fine so I’m wondering if it’s worth the update.
Just did a quick test on the VDB in my office. The sound is clear and louder than before. I don;t hear any static on the phone. The VDB side seems to sound better than before. But I primarily use the VoIP process as well.
If you want, I can try to do a recording later today.
Thanks! You don’t need to do a recording… I don’t use the VoIP though. I’ll probably update it as long as you can use the live streaming again ![]()
Updated and working without a problems so far.
I have not. Mine is triggering events as before. But I do set the sensitivity high. Maybe that is why I have not noticed a difference.
All sensitivities are set to 100 since before the update. Only difference since I noticed the issue has been the actual update. I have tried lowering sensitivity then setting it back to 100 and also rebooting.
Hello! This fixed my Error 05 when recording events via CamPlus. I still can’t watch past events but the new ones are recording as it should. Thank you!!
I would love to try out the beta firmware for the original video doorbell, but it says you must use the beta android app too. How does this play with others in the family that are NOT on the beta app?
The 4.25.0.245 production firmware seems to have trouble livestreaming for me frequently. I have to click “restart” in the app to get the livestream back (even though you can sync time, change settings, and restart it from the app). It seems to be connected, but does not livestream frequently (I even put in rules to restart it at sunrise and sunset).
Thanks!
