Are their any guidelines for the Wyze vaccum to be always plugged in? I wonder if there are chances of battery degradation if its always plugged in and charging?
Hopefully their is charging cut off built in the firmware.
Can someone please comment?
Welcome to the wyze community @sid!
You can leave the vacuum on the charger when not in use without causing damage to the battery due to the low-current mode when the vacuum is fully charged. It’s recommended to power off and remove the vacuum from the charger if it will not be used for a long time (more then a month).
More information found here: https://wyzelabs.zendesk.com/hc/en-us/articles/360050423572-Can-I-leave-my-robot-vacuum-connected-to-the-charging-port-
