WYZE cordless stick vacuum will not charge. 2 yrs old
Stick vacuum will not charge. Daily use sbout 2 years old.
Could be your charging habits shortened the battery health. Never store charged lithium ion batteries at 100%. They prefer to be put away at around 50%. When charged to 100%, use it.
I have exactly the same problem. My 2 year old Wyze cordless vacuum suddenly will not charge. I typically used it until it ran out of battery time (around 40 minutes) and then put it back on the charging station for the next time.
So I should put it back on the station and then disconnect it when it reaches 50%? Whenever that is. Check on it after 2 hours? And then charge it up when I want to use it again?
If I put it away at 50% I could clean maybe one room in my house. Then back on the charging station for the next room until it gets down to 50%?
This seems extremely unrealistic to me.
I’ve more or less liked this vacuum, except the bottom hatch now falls open by itself so I have to tape it shut with duct tape when in use. Also, emptying it is a real chore.
I guess you get what you pay for.
Unless a Lithium Ion battery has really good battery management software, they all react the same with regards to charging habits for battery health. The battery health will go down quickly if stored at 100% or left at 0% for a long periods of time. As I said they prefer to be around 50% when stored for lengths of time. If you want to get the most life out of your battery don’t charge it more than around 80% and don’t let it go lower than 20%. But the biggest factor to battery health is time. All rechargeable batteries are is state of degradation and have a limited life span. But maybe it doesn’t even matter considering we don’t know how long the Wyze cordless vacuum will last. At some point you may end up having to buy a whole new vacuum and/or batteries.
We face a common issue. We purchased our vacuum approximately two years ago, and it suddenly stopped charging without any warning signs. Initially, I suspected a problem with the charging adapter and purchased a replacement, but unfortunately, the new adapter didn’t resolve the issue. Now, the vacuum is essentially useless, as I’m hesitant to invest in a new battery knowing it might face the same fate in another two years.
Having the same problem, also tried a replacement charger and no luck. No hints as to what the problem is. I had used it down to 15% battery and when I plugged it in I noticed no light came on. Ordered a replacement charger and no luck. Really bummed. I’ve also had it about 2 years. I have loved it, but won’t be buying another after this.
I encountered the same issue with two Wyze Cordless Vacuums around the 2-3 year mark. When I contacted customer support, their initial recommendation was to try charging the vacuum with a different outlet. Unfortunately, when this did not resolve the issue, I was informed that my vacuum was outside the warranty period, and no further assistance could be provided. While I understand the customer service representatives were limited by their available resources and company policies, it was still a disappointing experience, especially given my long-term investment in Wyze products.
If anyone discovers a fix to this issue, it would be much appreciated as I now have two useless Wyze cordless vacuums.
Batteries don’t last forever, especially rechargeable batteries. 2.-3 years is a good run. Have you tried a spare/replacement battery?
great idea, but highly unlikely. We have 2 of the same vacuum. 1 failed completely (wouldn’t power on at all even when plugged in). The other worked perfectly, charged to 100%, discharged at a normal rate during use, and cycled between modes properly. We also used the battery from the good unit to test the bad unit. It still didn’t power on. We tried putting the battery from the bad unit on the good unit to see if the battery itself was still good. It did not work. The strangest part was that when we put the originally good battery and unit back together, that unit started behaving very strangely. It surged, cycled through power modes by itself, and was less consistently turning on. Shortly later, neither device would power on at all. while it’s indeed possible that there is a battery issue, the odds of it being the batteries alone and a device and battery going from fully functional to completely unpowered immediately after being tested on the bad device seems very unlikely. I will check the voltages with a multimeter soon to be sure. Is there a pin out diagram of the battery available somewhere to check against?
None that I know of. From your swap testing, it sounds like your vac may be dead, not the battery. I also have 2 of these vacuums with 4 batteries. Both vacs are still going strong, but one of the original batteries finally failed. It had a very short run time before not accepting a charge.
Same problem here. I really liked the vacuum. Now, suddenly, when I plug in the charger, the state-of-charge indicator says 100%, and charging shuts off. Try to use the vac, it says 100 - 43 - 0% in the period of about two seconds, and the motor shuts off. I really hate to put it in a landfill. I’m not going to try a new battery unless they tell me they fixed something. But maybe, I can find a way to adapt to my Makita drill batteries. Does anyone know what the battery voltage is supposed to be when charged?
I had the same problem and now realize that I have two vacuums that look the same but they are different. The s version can only be charged with the charger that ends in the letter w and the original has a charger with no w on the end. If you mix them up, they won’t charge.
Did anyone answer the question ?
No. I still have the non-functional stuff, but have very little hope. Too bad, because I really liked the product.
