I did the firmware update today. How do I edit my map to define rooms? The robot assigned 3 rooms room1, room2, etc) during its initial mapping of our house but these rooms are not what I need. How do I change and rename now? Thanks…
After selecting the vac on the app, click the gear in the upper right corner. You should see an option “map editor” on the settings page. That’s the one …
It may be that I had only run quick mapping? What you describe did not work for me. Will see if it does once it has completed an actual cycle instead of quick map scan. I dunno
How did you guys score the update to .95? I’m stuck on .75 and it’s not prompting when I check the firmware. Drooling about the room editing, my bot marked 85% of my house as one room for some reason.
You’ll have to wait until you’re notified that the update is available to you.
The only manual control is the ability to select a room or rooms and tell it to go clean. Also, with this update you can tell it to come home, from the app.
