Wyze V-3 Red Dots
First Camera in Daytime Excellent Picture. Also Picture great at night time, only
problem, Is I get 2 Circular Red Dots only on Night Vision, They both about 1/8 in
in Diameter. I moved the camera to different locations, and still the Dots Also to be
fair I have the camera sitting on inside window sill. Anyone experience this?
My phone is a Samsung Galaxy J3
@mr.crane
Can you post an image of what you are seeing?
Reflections from the LED lights (?). These can be disabled and may very well not be necessary with that model’s crazy good night vision.
That sounds like the IR lights or the indicator light reflecting like @Customer said. Both can be turned off in the camera’s advanced settings.
You guys are Correct, I went to advanced settings, Then night vision mode and turned OFF, the Camera Status Light! Now all is Good. Thanks for help! The Quality picture of this camera, is
as good or better, than my Swann 6 camera DVR system, which cost over $300 bucks, like a year ago. Thanks for your help for those who responded.
How do I post pic from my gallery?
Yep, two status light reflections from the double pane glass.
Yep , I have my night vision OFF as it picks up too many bugs flying around.
If you really need night vision, get a separate outdoor IR flood light.
Put a shroud around the cam so it dowen’t pick up reflected light from inside. :slightly_smiling_face:
