my V3 camera has blue or orange spots during night vision, anyone know what could caused this thanks and stay safe
Welcome back @jsui.z28!
Is your camera pointed in a window?
This could be the status light on the front of the camera. You can disable the light in the camera’s advanced settings.
hi thanks for the fix I should have checked that LOL be safe
happens to the best of us
Was that it? The status light during the color at night?
“Night vision” mode should be black and white, so having colored spots is an issue. That what I thought when first reading the post.
Hi now I’m having problem with my other V3 outside cam works intermittently earlier today worked but now error code 60 n 90 . Looked at device setting no WiFi now but all my other V2 n V3 are working ok. Maybe I should’ve gotten something else thanks and stay safe
Yes so far yes it’s fixed thanks
have you checked how good the wifi is where that camera is? im always amazed at how much faced insulation can block signal…it’s like a tin foil hat for a house
