Wyze Thermostat Turns off heat mode trigger
I’ve got a rule setup that when my Wyze Thermostat Turns on heat mode, it will turn on a Wyze plug which has a fan connected to it. I’d like to be able to turn off the Wyze plug when heat mode is turned off. Unfortunately there is no trigger for “Turns off heat mode”. Any advice?
I found your post because I was thinking about hooking up the same thing. You should post it in the Wishlist, so people can vote for it
Thanks! I’ll do that.
