Wyze thermostat loosing connection
Anyone using Wyze thermostats? My question is does anyone experience loosing connection often? I have two of them and have tried the obvious fixes but continues to happen every few days. Have to power them off and they reconnect. Kinda hard to do when away from home and the reason why I went with a WiFi thermostat in the first place. Also of note
I have a Wyze mesh router.
I do
Yes. I personally don’t have this issue, but there are many people who do.
It’s a known issue. Wyze is now working on a fix for it:
I hope that helps answer your questions…you are not alone, Wyze is aware and says they believe they found a possible solution for this. Hopefully it launches for you soon.
