Wyze switch toggle smart bulb
Wyze switch and Wyze color bulb.
The switch has an option for additional controls, 2 clicks, 3 clicks, long press. I’d like to use the long press to toggle the smart bulb on and off. I found the option to turn the bulb on OR to turn the bulb off. If I make two rules, one for turning the bulb on and another for turning the bulb off, I get a conflict message.
Is there no way for the long press action to turn a smart bulb on then off on the second press?
Thanks,
D
EDIT
What happens to the switch if it loses WiFi? If it’s running on a schedule, will it remain in the last state it was in until WiFi comes back on, the resume the schedule?
Currently there is no Toggle Rule. So Long Press can either Turn it on or Off but no toggle. This is currently an item in the Wish List location:
Add More Triggers for Wyze Rules - Wishlist / In Progress - Wyze Forum
There are 2 modes you can set the switch to, located in the Single Press: Classic Control for use with non smart devices/bulbs and smart control to control Wyze Smart Bulbs.
If you are set to classic mode, then the lights will still work when WiFi is out. If you are set to smart Control, then there will be a possibility it wont work. This is because the devices are depended on WiFi.
I am set to Classic Control and then use the other press and Long events control other Wyze Devices in my house.
Thanks for the reply. Hopefully we’ll get the toggle option soon.
The switch is in classic mode, controls an outlet with a regular bulb. I guess once you set a schedule, it’s loaded onto the switch, so even if the wifi is lost, it will remember the schedule?
D
