Wyze Switch - Control Floodlight
Please allow control of Floodlight from the single press of Wyze Switch under “Smart Control”.
While you are waiting, try this! (substitute “Turn on Floodlight” for action):
The Wyze floodlight needs to be smarter. I had hoped there was a way to activate and deactivate the floodlight using a Wyze switch. The option is there to operate Wyze bulbs using the switch while not actually turning off power to the bulbs. It needs more seemless i tegration.
Can we have input from a Wyze member about this matter? Will this be added to the device/app soon?
I was shocked to see that I can’t add the BR30 bulb to the Wyze Switch using Smart Control. Creating rules is a lengthy workaround and doesn’t fully allow for double or triple presses.
The lack of floodlight control via switch or via Google Home is the only reason I haven’t replaced all three of my floodlights with these. Common guys…
