Wyze Smart Window Shade/Curtains Motor or Blinds
I have lots of shades in my home which I would like to automate. I see several smart controllers out there which can be added to existing shades. They just mount to the wall and turn the cord, but they’re all crazy expensive (Soma, AXIS, MySmartBlinds , et al.). It seems like all that is needed is a WiFi interface connected to a small motor. It shouldn’t be much more expensive than a Wyze smart light, yet no one is selling one for less than $149.
If Wyze could make one of these for <$10 I’d very quickly buy one for every shade in my home, and maybe convert some blinds to shades just so I could add more automation.
Thoughts?
Yes this is such a needed item in the smart home space.
Absolutely, I can’t believe there isn’t a better solution out there for this! Even at $20 - 30 / device I feel like would still be reasonable. This seems like a perfect product for Wyze to stand out in the market with.
I imagine the governor needed to keep the motor from eventually burning out makes them expensive.
There aren’t any good cheap options for IoT blinds, Would love to see an inexpensive Wyze Blinds product. I assume it wouldn’t be much more than a battery-powered motor that would attach to any standard blinds.
Here’s an expensive version: AXIS Gear | AXIS LABS USA
I’d be happy with an integrated smart wand that turns the blind slats and doesn’t fully raise or lower the blinds themselves.
We have cordless blinds so they don’t work with most of the expensive after market options out there. And after going to cordless blinds, which we are slowly replacing all blinds in the house with, I will never go back. With corded blinds I’ve had them rip out of walls, their anchors, or have the cord simply degrade and break one time to many.
If I could only control it through Google Assistant and the Wyze App I’d be happy, but if they came out with the ability to have them open or close based on sunlight, time of year, and/or temp that would put me over the moon.
Any chance you might look at bringing out blind motors for after-market install? Brunt, Tilt/MySmartBlinds and Zemismart are already in the space but I think it makes sense, if Wyze is to fill all the bases in a smart-home security & automation space.
Here’s what I’d like to see in such a module… I’d like it to be a module that mounts to the existing blind slat rotation wand connector - preferably with a drive pass-through for manual operation. So, you’d remove the twist wand that controls the blind slats, then connect the Wyze motor, then reconnect the twist wand to the bottom of the motor. Twisting the wand would still adjust the blind angle.
Motor would be powered by solar power since it’d always be near a window.
Solar panel power output could be used as a sensor for solar intensity.
In winter, could be set to maximize solar energy passing through the blinds to warm the room.
In summer, could be set to minimize solar energy passing through the blinds into the room, keeping it cool.
Blinds would regularly adjust as the sun moves across the sky to maintain the correct angle with the blinds.
Could be driven by Wyze cam detected brightness. So you could draw an area on the video and if the area brightened past a set threshold, the blinds would adjust to reduce the light in that area below the threshold - so you could, for example, control the intensity of light on a baby’s crib.
It could have a “partly cloudy” mode where the blinds would block out light during a period of direct sunlight, but open the blinds whenever clouds obscure the sun. So the blinds would only be closed when needed.
Should also have a night-time mode - where the blinds close for privacy when the interior illumination is greater than that of the outside (making it easy to see in the house - a “Close at Sunset” mode).
Another cool setting would be “Open at Sunrise”. So it’d detect sunrise and open the blinds to help get the day started.
Could also be controlled based on temperature and automated with Wyze switches and motion sensors (open the blinds when I enter the room, but close them otherwise).
After researching automated window treatment solutions and since you all are the masters of creating products that vastly undercut the market, I wanted to toss something your way as an idea. Considering that you already have motor control architecture in your pan/tilt cameras and the new Wyze Lock, how about automated roller blinds? They need a small motor to rotate the cable, which could likely be handled by a battery operated system and controlled via the app.
I mention this as other solutions sit in the $100 - $500 range which ostensibly appears to be your go-to when it comes to undercutting the competition.
I like this idea – but they’ll need to implement localized sunrise/sunset scheduling first. :slight_smile: Haha
Would love to see an affordable build of these!
I see you are active on the other post, so just a quick reminder if others stumble across this: IFTTT does provide sunrise/sunset actions using Wunderground weather for localized areas. I use it for some Wyze Bulbs in floor lamps in our living room that otherwise does not have any lights then we just manually term them off via the Google Home’s “Good Night” routine when we are heading to bed.
It should be schedulable, as to when the blinds should be opened and closed, and affix to the existing blind hardware.
[Moderator Note: This is a merged topic]
OK, idea! Make a thing to adjust blinds. Move chain to adjust opening or raise and lower. You already have a motor, so… I am sure you can make one for alot less than what is charged in the world.
Then for “door Knobs” vs dead bolts. If you could have a device which still uses the key but can unlock a door knob with the little doohickey you turn on the inside. MANY front doors have this in addition to the deadbolt. The MAIN point is the key is still usable.
Create a wyze product to open and close blinds (horizontal) and curtains (vertical). There are many products out there, but they are so expensive. Easy battery replacement would be a plus, and the ability to hide the device so it is not noticed.
You guys make some great products for relatively decent pricing. Have you thought about getting into the automated blinds and curtains space?
I would love do you see a device for plantation shutters. This would be great for security and convenience. I could open and close my blinds from work, for dogs, while on vacation. For seniors/hospice patience in bed they could open and close blinds with their decide. Something simple that attaches to a couple of the blades where I can open and close them at a specific time of day and or manually open them with the app. It could simply be a device that is attached to two blades that would make the rest of the blinds open. Or it could be a device that attaches to the opening bar for the entire row of blades.
I absolutely agree with this request! Smart home devices are pretty much all the same with the exception of smart curtains/blinds. The devices that are out on the market are drastically over-priced, limited to roller blinds or a very specific kind of curtain, and are either hard-wired into the bloody walls’ wiring (very few good ones are plug-in, and none are battery-powered), and finally their apps are rubbish and few of the apps work with either Alexa and/or GH.
I’ve seen a few companies coming up with motorized window blind wands that you can control to rotate the want to open or close the blinds. Is this something Wyse would consider? I would like to have everything consolidated into 1 platform.
https://www.myewand.com/about-the-e-wand
Been looking for a good solution for the blinds, would love for Wyze to take this up!
