Hi everyone, I am not sure if this is already in the Wyze community but I have noticed that a lot of people have had a problem with there Wyze sensors were when the battery dies and you replace it, It does not work anymore. I have read that if you let your Wyze sense battery completely die, they will probably not work again when you replace the battery. One easy solution to this is to watch carefully for the low battery sign and replace the battery as soon as possible.
As many of you probably know, Wyze is coming out with a Wyze sense vs. 2 which will most likely fix this problem.
