Just wanted to share my current experience and hopefully help others avoid my situation. I was an early backer on the Wyze Sense Starter Kit (March 2019) and purchased an additional kit after they launched (August 2019). Sensors worked great up until this past month. All 6 contact sensors and 2 motion sensors have needed battery replacements at various times since April 2020, not bad for original battery life. The last week has seen all of my sensors disconnect, but I managed to get 2 contact sensors and 1 motion sensor connected. The rest were frustratingly not functioning correctly. Turns out that there’s a very important piece of information that wasn’t very obvious to me until I found the support page:
Important: Waiting until the battery dies may result in the sensor being unusable even when the battery is replaced. Replace the battery as soon as you see the “Low Battery” warning. If a sensor of yours has died and is unable to connect even after replacing the battery, please contact our support team for help.
Not that big of an issue, contacted support for my 4 contact sensors and 1 motion sensor that refused to connect. Here’s the fun part…the warranty is 12 months from date of purchase. The batteries last an expected 12 months. Support page solution for a sensor that won’t connect? Contact Customer Support.
I got lucky and they’re willing to partially replace what went down, but don’t make my mistake and wait for the batteries to die. At that point, you’ll be out of warranty and out of sensors.
For reference:
Battery length support post
Sensor not connecting support post
Warranty post
