I was disappointed to find out pressing the reset switch on the rear of the Sense Hub cleared out the table of sensors causing me to manually reset every one, Several require a ladder to access. Normally devices use this type of switch for a reboot or power cycle reset and not a reset-to-factory action. At the very least it should be a long-press to clear all the configuration.
This would not be a problem if users could save the configuration and restore it after a reset.
