My Sense Hub went offline and I can’t reset it and reinstall it. Any suggestions?
You may need to delete ALL sensors, keypads, and the hub from your configuration. Then, press and hold the reset button on the hub for about 20 seconds and you should get a prompt saying to start the installation. Then you can restart the whole process. You might be able to get away with just deleting the hub, but not sure. Try that first.
