Wyze sense being offline and hub extremely hot
My wyze sense stopped working and was offline. I’ve resetted the cam unplugged and plugged back in the hub, nothing worked. In the process I’ve noticed the hub was warm and when the usb port was extremely hot. Anyone else noticing this?
Keep in mind that this forum is primarily a user to user community. If you don’t get a helpful reply here, I suggest you file a support request including the log files for more help. You might want to go ahead and submit your ticket now as there is somewhat of a backlog. If you end up getting the issue resolved before support contacts you, then you can always let them know that it’s already resolved.
