Wyze Scale X command line utility now available
I’ve released a command line utility for communicating with a Wyze Scale X via bluetooth.
You can list, create, modify and delete users, query the cached weights, set the display units on the scale, etc.
See: GitHub - JesusFreke/wyze_scale_tool: A utility for reading from and managing a Wyze Scale X
Happy Integrating!
That’s super cool, how did you reverse engineer the protocol?
This is probably not the ideal place for discussing that, but you can probably get an idea from some of my other projects :slight_smile:
Wow! So cool! Thanks for sharing it publicly! I wish more people did this kind of stuff.
This is great – thanks! Do you think this would work with a Raspberry Pi Zero W? Google seems to think that the scale is BLE 5.0 and the RP Zero W is BLE 4.1. Would that be a problem?
Yeah, I’m not sure offhand if it’s ble v5 or what, but even if it is, it should be backwards compatible with v4 hardware. I’d say give it a shot and see if it works :slight_smile:
Thanks for your quick response!
