I just picked up a wyze x scale. I do not want to connect it to blutooth. Will this cause problems when first turning on the scale? The instructions say to have my phone and blutooth turned on before turning on the scale. I chose this scale because it is supposed to be very accurate and I only want to know my weight.
As far as I know, Bluetooth is only used to pair the scale with the app and sync your readings, not to take the measurement itself. So the scale should still show your weight on its own display when you step on it. If it asks for pairing the first time and you would rather skip it, I would try stepping on it as is, and if that does not work, a one time pairing and then turning Bluetooth off on your phone afterward should be fine. Maybe double check the manual on that, since I am not 100 percent sure about the first power on step.
Bluetooth has to be on to add the scale to the app. during setup. V4 camera is the same, Bluetooth has to be on for setup, better than the old system of scanning a QR code to set up a V3. ![]()
