After latest app update my scale is showing weight and body fat on my Home Screen see picture. I can’t seem to find a way to fix it so it just shows the Wyze scale like it used to be where it was just a button that I tapped to open the scale.
That is what happened to my older Wyze Scale WHSCL1 (non-ultra) today too after the Android App updated to 3.21.0(955). It still works, but it takes up two tiles on the favorites screen. I deleted my scale from the favorites (unstarred it under devices), and use it only under devices till they can get a fix out. I knew I should have held off on the update.
Most wouldn’t consider it a big deal but it bugs the hades out of me to see that. I even deleted my scale and re-installed it and had the same thing and tried clearing cache on a hope. Hopefully it gets sorted out quickly.
V3.21.0 (16) Thought I would add that.
Unpopular opinion, but I absolutely love the new display for scales on the favorites tab.
My criticism is just that I wish it would always display the most recent accurate weight from any Wyze scale like the scales themselves show if you open them in the app. It’s currently showing me an old weight from at least more than 2 weeks ago.
When it first showed up it wasn’t showing any data at all, but in updated within the last few days to show me a measurement that is at least 2 weeks old or more. So I am a little confused about how it works. It should be showing the same data the scales show as the most recent measurement from any scale. That is the biggest issue to me.
I totally understand people who wish it would go back to taking up 1x1 on the grid instead of 2x2. That’s a valid preference. I personally prefer the new layout overall, slightly…at least I would if it showed accurate data (which it currently doesn’t).
Hopefully they will give the user the choice to have 1 versus 2 tiles.
Agree. Remove the extra data and two wide tab. Let us decide what to show. Why would Wyze force this into users ? It doesn’t fit on Fav screen now and I can’t quickly looking at the five tabs I need daily/hourly. Thanks but no thanks !
Wyze tests but fails again.
Glad to see the new update fixed the scale 2 tile problem - not.
Is Wyze going to force us to live withe the 2 tile scale problem because they know better what we want than we do?
Who wants to display their overweight info so prominently? Is this a fix to a problem that wasn’t really a problem?
Don’t really know how to take your reply - tongue in cheek or sarcastic.
It’s not the fact it shows people’s weight and other info the scale provides - it’s the fact that Wyze should not be making decisions for its customers when they did it correctly until just recently.
Definitely not sarcastic! But it’s like the iPhone’s new treatment of their unlock code, which dims the screen except highlights the digits you push. It’s like advertising your security code. This isn’t that bad, but I don’t want my numbers in big bold letters when I open the app.
So we agree then. I misread your post then.
It is disgusting that Wyze has done this and like you say showing what should be private information on the screen when app is opened. Sure there is usually no crowd around most of the time but who wants 1 person seeing their private info?
Edit - been at least one update since this problem showed up and still no resolution?
Happy customers do not matter anymore evidently.
Todays 9/30/26 update STILL didn’t fix the scale problem.
Edit 10/1/26 does anyone know if Wyze is going to address this problem? Or has Wyze decided they know best what we should look at on the app?
Edit: 10/6/26 - another update and still the scale view isn’t fixed. Guess Wyze is part of Big Brother in that they know what’s best for it’s paying customers.
