This link will be helpful
How To Become A Beta Tester
When will it release? Please please.
@WyzeHongfei @WyzeGwendolyn Have beta app and vac set up as beta and still not getting firmware past 113 for multi-floor support. When is this rolling out to either everyone on beta or to stable?
Our engineering team is still working on one last bug fix before we can release the new firmware to everyone in the beta. I think we are pretty close to the date, probably in the next few weeks.
After months of waiting I just returned mine to Walmart and order a Roborock S4 Max⦠it has the multi floor. I have three floors! Canāt go without.
Mine also going back this week. I bought this over S4 max because of multiple floor function. I also use beta app but seems they canāt figure it out the problems having with multiple floor function. I this S4 max worth few more bucks. No need to reset map every time do the vacuum.
I considered trying the S4 Max for multi-floor, bigger dust bin, and dust bin full indicator, but look at the reviews of the Roborock app, they are abysmal. Good luck switching to the S4 Max. At least the WRV, albeit missing some features, is very reliable in my experience. Iām currently running stable firmware because they havenāt released multi-floor to all in beta yet. Hoping this is released soon.
I had a Roborock S4 (non-max) before Wyze announced the robot vacuum and I can confirm that the Roborock app was super hard to navigate. Even trying to schedule the robot to run at a specific time on certain days took lots of digging to find. Granted this was like 18 months ago, so itās possible itās different now, but that was my experience. The Wyze app was 100x easier to use.
If the Wyze can only clean 1/2 or 1/3 of your home what good is it? Iād rather have a bad appā¦
Oh, personally Iād rather just reset my map and let it start from scratch when I need to move it to a new floor. Itās only a couple button presses, and at least itās easy to do in the app.
If there were no plans to include multi-floor mapping, I would be considering a different vac. But since itās on the horizon, Iām good waiting for it and knowing Iāll have a good app to use in the meantime.
I have no-go zones so resetting those every time would be a pain.
Makes sense, that would be more effort than itās worth for sure. Hopefully they release the feature sooner rather than later
Yep. I am also waiting on the spot clean feature. That would be handy.
I just got the beta 1.6.173 that enables multi-floor and spot cleaning! Will be trying that out right away.
I got a notification that it was available, but when I downloaded it, there was no multi-floor or spot cleaning options that I could see. Am I messing something up?
I had both an update to the Wyzebeta app before the firmware update showed up, installed it, after the WRV restarted, then I force closed and reopened the Wyzebeta app and it was there.
On mine, on the screen with the map there is an icon that looks like multiple floors in the upper right below the gear icon.
I donāt see spot cleaning yetā¦but havenāt hunted through everything.
I didnāt realize I had to move the charging station tooā¦
I still didnāt get the invite. I do have the beta app. I am late to the party.
