Wyze robot vacuum Left and right wheels do not rotate / abnormal noise
Check whether the side wheel is jammed or entangled by foreign matters
Regularly check cleaning attempts.
The plastic gear inside is likely stripped a few teeth.
Mine did similar and I took it apart to find the main wheel hear missing 2 teeth.
The replacement parts can be found using the alternate information make: Xiaomi model: STYJ02YM
Best place is either Amazon or Aliexpress, to get a wheel assembley replacement.
Good Luck.
