I picked up a cheaper Eufy for $80 at walmart to use downstairs. Left the wyze upstairs. Works well enough for me. Not too unhappy about not getting multi floor cleaning as I’d have to manually move the wyze upstairs anyway. But it is disappointing about the promises made about the firmware and the lack of communication. Oh well
I purchased this in 2020 during pre-order. My robot vacuum is crippled and wouldn’t connect to wyze app. I was moving houses during the time so I unboxed this after 1 year and warranty is over. I am stuck with a vacuum as good as irobot first gen vacuum. Wyze hasn’t been able to tell me how to manually update the firmware through the onboard micro usb port.
@Rin - Where is this micro usb port on the Vacuum ?
BTW, for all of us waiting on the promised firmware update, I highly doubt it is going to happen. If you can’t be without the new firmware, and are still in the return period for Walmart, my suggestion would be to return it.
I’m no longer in the return window! What I WILL DO is file a class action lawsuit against Wyze for false advertising!!! I have the box with all the proof I need! I’ve already talked to an attorney about this.
Hey there! I have the Wyze Beta app and I’m still stuck on 1.6.113 nearly a year later. How can I get 1.6.202, .306, + or whichever is the current version?
I’m on the same situation as you are Trying to setup my vacuum but it’s not getting added to the app for some reason It’s connecting properly to my wifi as I can see the device fine but failing to add it on the app Its so frustrating and can’t use it yet as I havent done any mappings yet
Any help would be greatly appreciated
In my case, the only solution was to get a new device under a warranty exchange. I was never able to get that particular vacuum to talk with Wyze’s servers.
Still waiting for firm ware update. Still at 1.6.113. Was expected 1/2023 … nothing. Now Feb. Still nothing. Come on Waze. What is the current lie on when we will get this update?
I’d really appreciate an update on this issue soon. Feeling kind of strung along. Very reminiscent of the sensors that were promised as an addition to the thermostat a few years ago. Overall good products, but definitely gives pause on consideration of future purchases.
They are hoping everyone will forget about it!!!
Got an update notification from my app. 1.6.202 has been installed. Supposedly with spot cleaning and multi floor. Will check it out later
I’ve been on 1.6.130 (former Beta). No update yet offered on my device
My preorder og vacuum just got updated from 1.6.113 to .199 and right after to .202 with spot cleaning and mutlifloor!
Just updated 1.6.113 to 1.6.199 to 1.6.202
Took about 5 minutes at most and all looks good
Thank you Wyze!
I saw this email saying the update was out. Update went well 133->199->202 …took less than 5 minutes…I haven’t tried the multiroom or spot cleaning but I see the buttons for them. Thank you Wyze for FINALLY doing the right thing!!!
Hello,
Some my Non Walmart vacuum just updated to todays firmware release… great thanks.
My Walmart S model is stuck at 1.6.173. Please advice. Thanks
Here’s the announcement:
There are two versions, depending on whether you are on .113 or a later firmware.
Thanks. Mine got updated too.
Yeah!
