Once a Wyze Plug is installed and setup with a schedule does it need to have Wi-Fi?
Yes it does need Wi-Fi , without Wi-Fi the only thing you can do with it is , turn it off and on with the button on the side of the plug
Thanks, I thought that would be the case but, had to ask.
Will the set schedule in the Wyze Plug still work without WiFi network connection?
I do not think it will. I believe that schedules are stored in the cloud. Not on the device.
