I am clear that there is no real-time control for the Wyze Plugs when there is no Internet connection, but I am asking about pre-established schedules. For example, the Plug has a schedule to turn off the attached device at 4 PM and turn it back on at 5 PM. The Internet goes down at 4:50 PM. Will the Wyze Plug on its own turn back on at 5 PM?
If the Plug stores the schedule on-device and has a timer or real-time clock, then I would imagine that it can work. If it is purely dependent on the server to send the commands, then I guess not.
There are a few different versions of wyze plugs, but most of them support local schedules. Check inside the devices settings for schedules, instead of rules which require internet.
2nd Gen - Plug 2021 and 3rd Gen - Plug 2022 support both Local Schedules and Rules. Local Schedules are not Internet-dependent and will run without Internet.
