Hi, Group. I need to occasionally reset my WiFi router for whatever reason. It can go for months with no problems, then need a reboot daily before being fine again. Question is not about the router, but the Wyze Plug because the router is really hard to get to.
I considered plugging the router into the Wyze Plug. That way I could use the Plug to power cycle the router… buuuut then once the router is off, I would lose my connection to the Plug of course!
Anyone know if I can create a Rule for the Plug - i.e. turn OFF for 5 seconds, then autonomously turn back ON, knowing that the WiFi will be shut off during those 5 seconds? More clearly: Will the Plug continue to work through a Rule if WiFi is disconnected while it is executing?
