Updated app without issues. No plugs of this version. I didn’t know plugs had an overheat warning, is that like if the device attached is too much current, it won’t damage anything? Thats a great feature.
Strange. Is your Plug CFH a 2021 or 2022? I noticed there are 2 different branches in release notes. My 2021 plugs still show up to date with 1.2.0.206:
I have tested Live Stream on iOS and Android. Android has no issue and streams as intended. However, on iOS it will start the live stream and then hang. Putting my phones side by side, I see the iOS freeze and Android continue. Also note, if you take your iOS device, turn it landscape it will start again for a few seconds then stop. So it seems anything to cause the screen to refresh allows it to start for a bit and then freeze.
Confirming VDBv1 on FW 4.25.1.314 crashes Android 2.37.0(b116) app upon return to home tab as reported by @Use_less.
Does not happen every time, but it will crash the app eventually. Experienced two crashes in 8 load\return cycles. Screen record video available by PM.
