Does not fully rotate when unlocking. Is this common issue or do I have a bad unit? Only unlocks if door is open, when closed it will not turn more than 60% .
Welcome to the forum @eric.ku.ba ![]()
Couple of thoughts.
Is the bolt pressed against the frame when the door is closed?
Have you tried to recalibrate the lock?
Might have to open it back up and make sure the cam bar is lined up with the Cylinder properly
Welcome to the Forum, @eric.ku.ba! ![]()
I wonder if you’re experiencing something like this:
Is it possible that the batteries aren’t fully charged and the motor mechanism is struggling because of that? How tight is the fit of the latch into the jamb when you actuate it manually with the knob? A more detailed description of your experience might be helpful.
