Wyze outdoor cameras unreliable
I have 3 v3 cams which are reliable and 6 outdoor cameras that are not. The base stations are both up and up to date as were the cameras a day ago. They’ve all gone to offline status bar one today for the second time in a week. These things can’t be relied on. Having to restart my router and each cam individually once a week to get them going is not acceptable.
I run Google nest wifi and all the other devices are up and running. These things need a proper remote reboot option. I suspect I’ll be binning the lot in the very near future unless the performance improves
So I’ve read about V2s and V3s going “offline”, but are’t if you select them. Is this that? Can you select them and have them work?
No- the wireless bridges are online but all the outdoor cams are not reachable and show as offline
A logical first question is whether WiFi strength is sufficient to reach them outside. Reach them consistently, that is.
One of my two outdoors cameras died after 18 months of use. I understand they are in expensive but I expect better longevity out of a product. I will not be replacing it with another Wyze product.
I had one Outdoor cam during the Spring at 3 weeks stopped charging. I Emailed support (not wasting time calling) and toss the Cam in the trash. I am running 2 Outdoor Cams which are working OK (yet when the Network is down 1 Cam battery drains). I am running 2 Ring Outdoor Cams in Parallel and Ring is fantastic…They just work very well.
Yep under 5 metres. They are all affected
