Wyze out door camera's
I love Waze cameras the only thing I’m finding out I have an issue with is all of my cameras that I have purchased for outdoor use are failing one by one four of my newest ways and cam version 3’s have failed within the first month of ownership I’m having trouble getting them replaced and am having trouble even getting them repaired they were fine when I first installed and mounted them then all of a sudden they won by one have quit working some no power and won’t come on at all and some just won’t paying and tilt just wanted to put this on here and see if anybody else was having problems like with their cameras. I have also tried all the troubleshooting Solutions I’ve been given none of them have worked so far.
If you’ve had multiple failures, I would suspect something causing water to get in. Have you put a “drip loop” on each one (the mounting bracket on my OGs has a clip for the wire to help with this, not sure about the v3s)? Are they angled in such a way that water might get into the speaker opening on the back etc?
Note that most of the cams pretty much lose their IP rating if mounted upside down, not sure what position yours are in.
My outdoor cams are great too but one has died. No power can’t bring it back at all and they don’t offer a similar option. Very disappointed
Pretty much all their cams are outdoor cams at this point.
The original outdoor cams are pretty much obsolete. If you can hardwire power, go with the v4 or OG (both on very good sales right now). If you need battery, the battery cam pro is the way to go.
