Wyze OG not recording "Smart Detection Events"
I have 2 cam OGs, and if I set the event recording to all events, everything works fine. I can see every movement but if I move it to smart detection events, it will not record anything. I’ve set up the custom detections to see the person, pet, vehicle, and package,ge but still nothing seems to get recorded.If I switch it back to all events, then everything is recorded but if I try to filter by person, pet, or package, nothing is shown. The firmware on the camera right now is 1.0.98. I do have Cam Plus and this cameras are registered on Cam Plus. Just a side note: I do have several other Wyze cameras, different models, and they are working just fine. From what I read in this forum, I thought all the firmware in these OG cameras had been updated to detect smart events. Am I mistaken in that?
Have you tried the “reset services” option in the settings? Then go back and set up the smart detections you want again.
@dave27 yes I’ve tried to reset the service. I’ve tried to reboot the camera. I’ve tried turning the settings all the way off and the settings all the way on. The only thing I haven’t done is completely reset the camera but I don’t think that’s the problem because I have two of these and they’re both doing the exact same thing. There must be a software glitch somehow, some way, for these OG cameras
You’re not mistaken about the original Cam OG: Wyze’s release notes list Smart Detection Events as added in firmware 1.0.67, with Cam Plus required for object detection. The same Cam OG section lists your 1.0.98 as a later release. That documents intended support; it doesn’t explain why your two cameras aren’t classifying events now.
Since you’ve already reset services, rebooted and toggled the settings, I wouldn’t start by repeating those steps or factory-resetting both cameras. Could you note the Wyze app version and whether an unfiltered event with a clearly visible person gets a person label at all? A controlled comparison at roughly the same time with an affected OG and one of your working cameras could give support a concrete example. Send the approximate times, camera models and firmware versions through Wyze Support, keeping account details and private footage out of this public thread.
Wyze app version: V.3.251 (1037) on Android 17.
As long as I keep it on “all events” it records everything. None of the events have a label. It just says “motion detected.” Once I toggle it over to “Smart Detection Events” I get no recordings whatsoever. Nothing is detected. In the Customize Detections section I have everything tagged:
  • person
  • friendly faces
  • pets
  • vehicles
  • garage doors
  • packages
  • other motion
I think I’m covering all my bases.
I’m really not sure about setting up another camera. That would mean I would have to uninstall it in one location and then reinstall it next to this camera that isn’t working. It’s not an easy task, as you need extension ladders to get to these cameras.
I’m really not sure what my next move should be but the easiest option would be just to replace the cameras, I would think.
