Wyze night light not turning on when approached
Hi All,
Purchased 3 night lights and they turn on ok and are fully charged. I put them in auto and they sync and work ok. But when I change them to AUTO mode, the won’t detect motion. The only turn on when I take them off the magnetic plate. They are installed at 1.2m from the floor, as indicated in the guide.
Any ideas? TIA
This may sound like a silly question, but are you sure you have them mounted in the correct orientation? When facing the night light, the switch and charging port should be located on the right side.
