The problem with no sensor goes beyond the lack of notifications. Unlike the Wyze Lock, this door doesn’t know when it’s been left open (intentionally or otherwise) and will-if configured to auto-lock-extend the deadbolt even if the door is ajar. This leads to mangled door frames! I wish they could have just done an external keypad version of the Wyze Lock because the outside part of the Bolt is AWESOME ![]()
Yes, I have had this extend the bolt on me while the door is open a few times
I agree that is not ideal. I also agree with the suggestion to basically copy all the benefits of the inside part from the original lock, and the keypad part of this lock bolt and it would be really ideal.
I just installed the bolt… looks nice, feels solid. I echo what the others have said - being able to connect it to my home network so I can manage/monitor it remotely would be a big plus. I installed this lock to replace a (working) electronic deadbolt by Sunnect. That company is no longer in business and I assumed my unit will fail at some point - it’s 9 years old - and decided to try the Wyze option. Although my previous lock was a ‘dumb bolt’ it did have one feature that was appreciated. The strike-plate had a small magnet encased in it. If the door was open (i.e., getting fresh air), the bolt would detect that the magnet wasn’t nearby and would NOT auto-lock. That kept my door frame in good shape over the life of the lock. I could walk back into my home and mindlessly pull the door closed as I walked by without having to stop, think about it, inspect whether the bolt was extended, manually unlock it so it would clear the door frame, etc. In summary - incorporate the option to add a bluetooth/wifi gateway and add the ability to disable auto-lock if the door is open.
Thanks for the tip about using a phone as a power source. That beats having to stash a power bank somewhere outside your home.
Is that just a regular Lightning to USB-C cord/adapter? I can tape one of those to the inside of my mailbox ![]()
It is.
As mentioned. When I tested, have the cable plugged into the phone first, then plug into the Wyze Lock Bolt. Should you ever need to use this method.
@wabbit9290 I agree with RoboNaught response to you - since price is a concern for you, you’re ignoring a major reason why this cheaper than the original Wyze lock-- the mechanism of tumblers to accept a key, and work only with the correct key, and also be resistant to bumping/picking is very complicated. This certainly isn’t perfect, but the Kwikset one you showed starts at about $200, Kwikset’s very cheapest similar lock (which needs a Z-wave controller) starts at $149. So for those who have a second entrance as backup (my use case), this is an excellent option and price.
Well then why don’t they just build it similar to the Wyze lock where you don’t need a key but use the original key and outdoor lock setup, just have the keypad separate? and why is the Original Wyze lock so much more expensive than this and then have to spend even more for the keypad?
I’ve had my lock for a few weeks now and am pretty happy with it. I have a few questions/suggestions:
I wish the keypad was alphanumeric. It’s easier for my kids to remember a word than a number.
It’s a bit annoying that once I set a passcode in the app, I can’t access it again. Obviously, the fingerprint reader is supposed to be the primary method of entry…but that means it could be months before someone needs to put in their code. This means there’s a high chance of forgetting it, and I have no way of accessing it in the app. So I’ve created a separate note on my phone that contains the codes (password protected).
I think a compromise would be password protecting the Wyze app, or even just the Bolt lock section—and then letting me see the codes.
I SPOKE TO SOON!!
My lock has revered back to not allowing any users to be added. Lets you Add, create name, Then… as soon as you try to set a code, it just times out saying Bluetooth disconnect. Does this no matter what. Also, 50% of the time when this happens, the only way to get bluetooth back is to restart the app and pull a battery out of the lock and reinstall it. Very annoying I have to say!! If I can’t add users… why have it? It then becomes the same as everyone having the same key.
This does not work with the iPhone 12 Mini, alas. Maybe my Lightning to USB C cable doesn’t support bi-directional charging?
I don’t have a USB micro B to C cable, so I haven’t tried it with my Motorola yet.
Works fine with a power bank using a USB A adapter on a C cable.
I love the lock but have 2 issues with it,
- I wish it could recognize when the door is open so it doesn’t lock while door is open.
- I wish they had like 2/3 minute autolock option as 1 is a bit too short and 5 is too long.
I just set up my WLB two days ago and I think I have discovered a MAJOR flaw in the auto-lock system. Can someone else confirm?
The option to ‘Disable auto-lock’ during certain hours to me means that WHILE it is enabled your door should never be unlocked for longer than the time duration you pick. However, if the door is UNLOCKED when the ‘disable’ time ends, the door does not lock. It just sits there happily unlocked until someone locks and unlocks it again, and then when the time passes it auto-locks.
Basically it’s functioning as “auto-re-lock” instead of “auto lock” if you use the ‘disable during certain hours’ option - the two are not the same.
This is a major flaw, and an easily fixed one.
STILL can’t add users! Since I got it new when it came out. It only lets me add myself and anyone physically present during setup. Once it is setup you cannot add users or even add another fingerprint to yourself. It just keeps timing out saying Bluetooth Disconnect!! Yet the lock still works. I can lock and unlock it from the app. So most of my family and ALL in-laws etc cant use it at all because they can’t be added. The only way to add someone is to completely remove it and re-install it as new. However… there is no way to have anyone who is going to be using it all physically present all at the same time during setup. Why have a feature to add users when that can only be done at initial setup? I can’t believe there isn’t a fix for this by now.
Certainly sounds like a really annoying bug. What did Wyze customer support say? Did they have you submit a log?
I have to say, I expected better from Wyze. For some reason this product is getting zero attention. It’s been out for months now, and there’s not a SINGLE firmware update.
I wasn’t upset about the MAJOR issue with the “auto lock” feature, making it almost useless because I just assumed they would fix it in weeks. What’s going on @UserCustomerGwen is the lock bolt abandoned?
I contacted customer support at this point 2-3 months ago and there has been no updates.
Pretty strange.
I added someone few week after installation.
I also created a backup fingerprint for myself around this time.
Did you try to configure it with another device?
Rulwiz: Yes contacted them. Did not know why it was doing it. I did submit a log then but currently there still no fix or even a known reason why.
christiano: Yes I have tried it on my iPhone XR and my wife’s iPhone 11
It works. I just can’t add other users after the initial setup and closing the app. Anyone added after setup before closing the app will work. But… after that no new users or even being ale to add a second fingerprint to myself. So weird. I can’t even use the “temp code” feature to allow a guest in if I wasn’t there. When trying to add someone or a fingerprint to myself the App times out saying Bluetooth Disconnect yet it still works from the app.
@jimjrfl sorry to hear your device isn’t working normally.
I just tested on my Lock Bolt and I am able to set up new users and fingerprints without any problem, so I don’t know why it is not working properly for you, but it seems to be something fairly unique to your device.
- Did you try a factory reset and setting it back up from scratch?
- What firmware are you on? I am using 1.0.5.2 and it is working fine for me to add new users and new fingerprints.
It sounds like you contacted Tier 1 support and they asked you to submit a log while they escalated the situation to Tier 2 support. I am guessing they said they will look into into and contact you back by email in a few days or within a week or whatever the standard is, is that correct? If it is just your unit having a weird issue, then it’s not abnormal for them to do this before they consider a warranty exchange. If you don’t hear back from them within a week let me know and post your support ticket number and I’ll have someone look into seeing what the status is.
@jimjrfl
I am sorry you are still having issues with this. Can you try to add a fingerprint again and right after it fails submit a log and give me the log number. Also have you contacted support on this and if so can I have the ticket number.
WyzeJason: My original log submission was on Aug 8th Ticket# 2275007 Log# 675466
I just tried to add a finger print to myself. It does time out like when I am trying to add someone. It just sits on a screen with the spinning snowflake and NEVR times out. It will sit like that until I close it. But I did create a log for it. Log# 683705.
I then tried to create a new user and after entering the name and hitting “Set” in the Access Code section, like always… it just times out saying Bluetooth Disconnect. But like I said I can still operate the lock from the app! Anyway I created a log for that also. Log# 683711
Happy hunting! LOL Sure would like to know what’s going on.
Thanks
Jim
