Wyze Lamp Socket Not showing up in App
I have had a V3 Cam and just purchased the Wyze Lamp Socket. I got the camera to work. My issue is the lamp socket settings are not showing up in the Wyze App. Therefore, I have to turn the camera off at night. I have spent countless hours trying to figure this out, and read more information on this than I would care to admit. Is my Lamp Socket defective? How do I get it to work like it should. Thank you,
What cable are you using to connect the socket to the camera?
For the connection between the Cam3 and Lamp Socket, I’m using the lamp socket cable it came with.
So are you not seeing the socket as connected in the cams settings > accessories > lamp socket?
That’s where the settings are for the socket.
The boy thing showing up in that cameras accessory setting is Windsor sensor bridge. Which I do not have.
Thank you,
Are you sure this is a V3 Cam? Could you send a picture of the camera and a screenshot of the accessories page?
Thanks
I checked again and this not a cam3. My other camera is. I will buy another one and try again. I did check before but forgot I have two cameras, and my other camera is the Cam3.
Thank you,
Cary
That makes sense. The lamp socket only supports the cam v3 for control and settings.
I am having the same issues - nothing shows up under my camera. There is no accessories area under any camera or under any other section. I feel like this socket is a huge waste of money and I am so sick of Wyze products not working unless I spend many long hours fixing them. What a bunch of junk!
What camera model is this? Only the v3 and v4 cameras support accessories like the lamp socket.
A v4.
I’ve had a Lamp Socket with V3 to turn on with motion detection in the dark and it worked perfectly for years Until I updated to the V4 and did all the firmware updates, now my lamp socket is defective. Wyze messed something up in their updates. The cam gets power and works as it should but no longer does the light on with motion in the dark. Now I have to use my phone flash light and fumble through my keys. Restarting the lamp socket fixes it for about 30mins then back to not working. it just completely unpairs from the cam but still provides power.
I have the same problems with both the cam3 and cam4. Constantly have to restart the cam for the light socket to show in accessories. If the power goes out and I’m not home, I have to restart several times. I have four sockets and there’s always one that fails to connect and the light stays on. I spend far too much time troubleshooting and resetting.
Had same problem. Reverted the V4 5332 to 4188. Still buggy but got it working. Wyze really needs to fix this.
I finally gave up on the V1 lamp sockets and replaced them with V2. No problems with these.
