I purchased a couple of Wyze Lamp Sockets and discovered that my outdoor lights are “sunk in” and do not allow the Wyze Lamp Socket to fully screw in. I see on amazon where there are E26 socket extenders, but I am having trouble finding outdoor ones. Can anyone recommend a product to me? I only need a socket extender that extends maybe 1" or 1.5". Thank you! ~Chad
With exposed metal contacts on both ends I suspect there is no “outdoor” version. If your bulb is in a fixture it will probably be fine…
That makes sense. Thank you for responding.
I have this same issue. Did the extender work for yours?
