Does anyone know the dimensions of the Lamp Socket?
Welcome to the forums @stcornish
The Product page says the “Packaging Dimensions” are 60 mm x 60 mm x 88 mm or 2.4 in x 2.4 in x 3.5 in.
But the description is throwing me off with Packaging Dimensions… Not sure if that is the box the lamp socket is in or the device, but, you have to figure if that’s the box then the device will fit in the box, yea?
And if “actual” sized pictures the lamp socket is similar in size to the V3 camera.
